Can I use Convert to remove everything that appears between the first hyphen and the second hyphen (including the second hyphen) for instances such as "01 - Sound Dimension - Jamaica Underground", please?
Yes, use
Converter>Tag-Filename and write a new filename, probably with
$num(%track%,2) - %title%
