I would like the length (time) column to display as MM:SS.xxx, with three decimal places displayed. I have tried using %length% and functions like div(x,y), but can't seem to get the syntax correct. Any suggestions?
Which field would show you the fractions of a second?
The only ones I found are %_length% and %_length_seconds%.
To get the length out of the last field:
$div(%_length_seconds%,60):$mod(%_length_seconds%,60)
Thanks, ohrenkino. That helped a lot!
Here's what is 'working' so far:
$div($mod(%length%,6000000),60000):$div($mod(%length%,60000),1000).$mod(%length%,1000)
The only problem is that a time of something like 4:03.291 displays as 4:3.291.
Is there a simple way of forcing the zero in 03 seconds?
$div($mod(%length%,6000000),60000):$num($div($mod(%length%,60000),1000),2).$mod(%length%,1000)
or e.g.
$div($mod(%length%,6000000),60000):$num($div($mod(%length%,60000),1000),2).$num($mod(%length%,1000),3)
Very, very nice! Thanks a million!
You may have noticed that I didn't account for track lengths of 1 hour or more.
I doubt that I even have any, so I'm not too worried about it.
Thanks again, and enjoy the rest of the weekend!
This is strange.
I only tested this for mp3 files, and it was fine.
For FLAC files (which is what I use the most), I get all files with a time of 0:00.000.
Try
%_length%
instead of
%length%
Thanks for your reply.
When using:
$div($mod(%_length%,6000000),60000):$num($div($mod(%_length%,60000),1000),2).$num($mod(%_length%,1000),3)
I get 0:00.004 for a song that should be 4:03.291.
This result is for both mp3 and FLAC.
Also, if I use %_length_seconds% only, I get the number of seconds rounded to the nearest second. So %_length_seconds% won't give me fractions (decimals) of a second.
That is why I asked
See e.g. the help on variables with technical information:
I think that %length% was a user-defined field, inserted by the converter. An apparently the converter for flac does not add this field.
Yes, I had already been looking at that page you linked to.
I'm wondering if I could use the bit rate somehow. Take the file size (in kB) and divide it by the bit rate (in kB/s), to generate the time in seconds.
I'll have to experiement some more.
Thanks for your input.
I was wondering if there might be something I could add to Options --> Tags --> Mapping that would work for FLAC files to extract the length (time).
Anyone know?
