First time posting so apologies if this has been covered elsewhere in the forum; i searched as hard as i could!
Anyway, the forum has been very helpful for inserting lyrics to the several hundred songs I'm currently working with. I want to add a comment into all of my files but I want/need the comment to include line breaks. Try as I might I cannot get them to appear in iTunes as anything other than one continuous line.
I tried to apply the same principle as I used for 'unsynchedlyrics' ie Text File - Tag and then applying the "Replace @CRLF in COMMENTS" action but it does not seem to work.
Am I missing something obvious?
Thanks...
