I'm not sure if this is possible, but can a script parse information from a third web page. ie. from the index url, parsescriptindex takes you to the album url where there is a defined link to a third url where the information to be parsed is located?
Hope I'm explaining this correctly.
on a similar note, can parsescriptindex's be nested\in series?
ie. can two parsescriptindex's be used one after another in a script?
thanks
