okay, i'm using this program for a little while now and know the basics...
but now i have this little problem since the beginning and till now i solved it by deleting the doubles by myself. I hope there's an easier and nicer way though...
the problem: I use the programm basicly to change the tags of wma files. But if i load files, that contain brackets [], then it repeats the bracketed (?!) part again.
example: Album: Well Well Well [International EU Version]/International EU Version
heeeeeeeelp.. cause if i have an album with a lot of brackets, it's a hole lot of work..
thanks
