Mp3tag 2.44 Load playlist/cuesheet option displays the desired playlist file (.m3u) format. However, Open push button produces no results.
Have you selected the Playlist file and pressed OK?
(On this dialog iit is Open rather than OK.)
The dialog box shows "Open" not "OK" on the pushbutton. Yes, the pushbutton is being
pressed. Also tried "doubling clicking" on the object name. In either case, the dialog
box closes and an empty tag list is presented.
If double-clicking your .m3u in Explorer causes it to play OK, I suggest you post the content here for us to check the format.
