I've got an issue with mp3tag v3.0.1 on Mac OS 10.11 (El Capitan). When I try to load a folder with approx 600 files from an external hard drive it keeps only loading 45 files. When I copy same folder to another external hard drive it only loads 44 files. However if I move the folder to internal hard drive it is able to load all 600 files.
I disabled filters and yet this still appears to happen. For info, hard drives have NTFS formatting. Is this a known issue, a bug, or am I doing something wrong?
Os it does not look like a Mp3tag bug to me as MP3tag loads the files if the environment is right.
So check what is different in respect to access rights and other stuff with the locations that cause problems.
Hi Ohrenkino, thanks for getting back to me. I've had a look at folder permissions, and as far as I can see they all have same permissions.
Only differences so far that I can see are that, one is an internal harddrive with HFS formatting and the other is an external USB hard drive with NTFS formatting. All folders have same read and write permissions. Also I copied the same folder from the external hard drive to internal hard drive for tests, and not other way around.
I'm happy to try any other suggestion, to see what differences there may be.
