Logical/Maths Operators not Working
the problem was this
$if(%year%=0 .... simply did not work. it evaluated TRUE for every record. btw, this was literal '0's, not nulls.
i tried all sorts of different variations, but none of them actuallly worked as expected
eventually I gave up and did a work-around instead
but i would still like to know why it didn't work
by the way, i have solved all other fixes/problems, often with my great app Bulk Renamer Utility to help a lot - albeit for File Name only
btw, are variables case-sensitive? eg in above is Year == year?
This does not match the MP3tag syntax. there is no comparator =. You would have to use $eql().
See here:
You could have tried $if($eql(%year%,0),yes,no)
No, they are not. case-sensitive
ah!
hmmm. so no normal maths/logical operators?
ok, but very unusual.
but once you know, you can dfo as above as you suggest (with approp string reults)
many thanks
