I'm using MP3tag to tag my music. Typically I use the Discogs tag source functionality to fill all the need fields. When converting a music (I tried several converter) I loose track number and catalog ID information. Please see the picture (AIF to FLAC).
It could be that you have to add a mapping for these fields:
TRACK -> TRACKNUMBER
CATALOGID -> LABEL
See File>Options>Tags>Mapping
(in my installation there is already a mapping for TRACK:
Tag: VorbisCOmment
Source: TRACKNUMBER
Target: TRACK
You can also check if the converter you're using is actually writing those fields to the target FLAC file at all. You can see all fields that are in there via the extended tag dialog at Alt + T.
If those fields are not present, you can select the source AIF file in the file list and press Ctrl + C to copy the tag to the clipboard. Then select the target FLAC file and Ctrl + V to paste the tag to the file. This also works with multiple files at once, their order must match.
I'm using XLD on Mac. Apparently it does not contain catalogID so that's probably the reason...
Ideally I would like to find a converter that keeps literally all the tags I set with MP3Tag. Would you know one ? I'd like to avoid doing steps manually cause I have a lot to convert.
