Hello,
I am new here and very happy with Mp3Tag. I have only been using it now for 2 days.
Something strange happens when I edit tags of e.g. 10 mp3's at the same time, that all my lyrics suddenly disappear. Also after today's update.
These can no longer be retrieved anywhere,
I then have to copy everything back to the lyric field and that is a lot of work. Does anyone have an idea what I am doing wrong?
How exactly do you edit your 10 mp3's at the same time?
Do you select them the File List and change the values in the left Tag Panel?
Do you see the UNSYNCEDLYRICS field in the Tag Panel?
I select everything and then I change e.g. album name in the right field and when I have done that the lyrics that I have entered via the window link that I have activated via UNSYNCEDLYRICS or via the MediaHuman Lyrics Finder program
The value stands here on keep
Sorry , I meen I change the tag in the left
If you select, e.g., 10 files where the lyrics field is filled in, does it change to < keep > on the left?
Maybe also post a screenshot of the Mp3tag window in that state and of the field configuration in the Tag Panel, just to be sure.
Do they have something in the lyrics field when you select the files individually?
OK, now please double-check the configuration of the lyrics field again.
The default value needs to be < houden > in your localization.
I'm gonna reinstall and try again. I let you know
Unbelievable, I have been working on 400 CDs with my lyrics being gone every time.
I can tell you, I have reinstalled and it now works as it should, lyrics remain now.
Thanks for helping me.
That’s just great! Glad it’s working now ![]()
