Lyrics in UNSYNCEDLYRICS field
Hello,
I copied manually lyrics as a test in UNSYNCEDLYRICS field of one mp3 file.
I can now see the lyrics scrolling when this mp3 is played.
On other mp3 files already tagged with lyrics when I bought them, I have another possibility : when I tap on the cover, I can have the full text displayed instead of the cover.
How can I get this possibility when I enter the lyrics manually ?
I have the lyrics of many mp3 in .txt files : is there a way to import them automatically to the UNSYNCEDLYRICS field of the matching file ? For example I have blabla1.mp3 and blabla1.txt ? It seems it is possible but it is not clear to me.
Many thanks for your help.
See Action "Import textfile".
DD.20170819.1106.CEST
What kind of player is this?
Normally a player that shows lyrics scrolling synchronous while playing needs a special tag-field calle SYLT (Synchronised lyric/text). The tag UNSYNCEDLYRICS is not meant to have informations that make a player show synconous text. There is special software that helps to create SYLT-tag-informations like
https://www.compuphase.com/software_sylteditor.htm
I think the features you mention are special features of your player and maybe the player does not get the informations shown from the tags but from an online source?
Thanks
I am most probably stupid but, without any example, I understand nothing in that section
About the 2nd part of my problem ? :
Thanks
Where exactly is the problem with the given example from the help text?
DD.20170819.1542.CEST
I would like to import a variable lyrcs file , for example,
blabla1.txt to blabla1.mp3 "UNSYNCEDLYRICS" field
blabla2.txt to blabla2.mp3 "UNSYNCEDLYRICS" field
blablaN.txt to blablaN.mp3 "UNSYNCEDLYRICS" field
I have more than 200 mp3 and txt file so I cannot do it 200 times... Better manually in that case.
In the example, the name of the file "lyrics.txt" is a Constant. I would like it to be a variable with tne same name and path as the mp3 file itself .
Mark all your files in the list-view.
Then define an action.
Type: Import text file
Field: UNSYNCEDLYRICS
Filename: %_filename%.txt
