I've used MP3TAG to update about 17000 songs but just realized that the genre does not appear for any of my m4a files. I can see them in MP3TAG, but the category is empty (or something different) in xbmc, media monkey and itunes. Is there an easy fix to this?
If these programs have a database of their own you would have to use the function to update the database.
For iTunes you could use the "Information" function on a single track to force the update and see if the genre is actually there.
For updating the iTunes db there are a couple of scripts around - or you delete all the tracks from iTunes and reread them.
I do not know how to update the database (if there is one) for the other programs.
Unfortunately, I've tried that. I've clicked on 'Get Info' for a few songs in iTunes to no avail and have updated the library for other programs. (I know this has been done since other files like flac have been updated.)
I have same problem for mp4 files, and not just with 'genre' but with 'album' also. These fields show a value within mp3tag, but Vista explorer shows the fields as blank, and my phone's Winamp app thinks they are blank too. An easy fix would be awesome.
Thanks. I've been playing around and now I'm not getting repeatable results, so I am going to have to reset and do more comprehensive tests. I should note my test files were created by ffmpeg 1.2.
