MacOS Cover Tag Discogs - Check boxes reset
I want only a few tags get from the tag sources, so I had disable the not needed tags.
If I want tag the next song, so the the checkboxes will be the same.
OK.
But if I press break button in the search dialog ( First search window ) the selection is gone.
For the next search all checkboxes are on.
From my point of view, it is a bug.
Best regards
Vigeland
Good catch, thanks for pointing and the helpful description!
I'll fix that with the next release.
Fixed with v1.3.2. Thanks again for reporting!
Thanks, confirmed. It works for me.
