Here are some NICE suggestions I expect to see in the next MP3Tag release.
- IMPROVE LEFT COLUMN functionalities.
It would be very useful if I could edit some things directly from the LEFT COLUMN menu. Specifically Add/Remove text/digits in fields whitout changing the already stored texts/digits just the way we do with auto-nubmering and Actions sometimes.
I think it would be more intuitive if we could add something like this:
0/18 on the %track% field of the left column so MP3Tag will add info before and after without altering what's already stored in it.
I noticed a little problem though trying to rename the file when the %track% field is with the "01/18" format. Mp3Tag suggest to number the track as "0118". You can bypass this problem by adding a checkbox or something to tell MP3Tag we want the track number to written 2 digit only, reading just the 2 first numbers. I think a checkbox would be the ideal for that cause who knows if maybe somebody wants the tracknumber to be 4 or more digits...
There should be a way to remove info of some fields without needing to create a new ACTION directly from the left. For example I have a file named:
01-kruder.and.dorfmeister-speechless-kw.mp3
Would be also cool if the left column shows me the filename and I could simply write directly to the field something like:
"-kw" and then clicking on SAVE
so I would have the "-kw" on the ending of the filename removed with no need to go to actions and create a rule for that.
Yeah I know I can do it in another way by renaming the file using the tag as a source but what if the TAG also has in the %title% field the "-kw" ending too?
I believe it would be easier and faster adding some more POWER to the left column.
- Changing languages after MP3Tag is installed.
Somebody might want to change from German to English or to any other language after the installation is finished. I tried but I couldn't find a way to do it. If there is already a way to change the translation, please make it easier. Maybe adding a menu "Language" or something like that inside OPTIONS menu.
- Add a button in the left column with the file tag info with the function "Save Tag" so can change the info and just click the button instead of "Right Clicking->Save Tag".
YEAH I know there is already a SAVE button on the toolbar above, but it think putting it in the left column as well would turn MP3Tag more intuitive for beginner users.
- Adding some support to importing titles from "AMG All Music Guide" website.
Well I think this one is the harder...maybe an utopie but I always go to www.allmusic.com to look for the right info of my MP3 albums, like the year an album was released and the composer of a tune.
I think that's what I remeber so far
Keep up the excellent job.
