KEEBLER
February 23, 2026, 3:26pm
1
is there a way to mask the data?
example
suppose I have the year as a four digit number 1974
but i want to use the last two digits in the new file name
example
LYNYRD SKYNYRD - SWEET HOME ALABAMA (74)
i did this one manually,
is there a way to only use only a specific part of a cell for each song?
>next case
is there a way to extract part of a cell and move/copy it to another one
example
FORTUNATE SON (LIVE)
is there a way to move the (LIVE) to another cell and delete it from the title cell?
>next case
can you add a TRIM option to remove leading or trailing spaces
example
in the previous case - there would be a trailing space when i move the (LIVE)
or
FORTUNATE SON (LIVE), sometimes the titles have leading spaces
Convert Tag -> Filename:
%artist% - %title% ($right(%year%,2))
One way could be:
Search for space bracket LIVE bracket
Replace it with "nothing"
$replace(%title%,' (LIVE)',)
Then do the opposite:
Add a fixed text (LIVE) to whatever field you want.
$trim already exists - from the documentation :
$trim(x,c) trims all leading and trailing whitespace from the string x. The optional second parameter c specifies the character to trim.
KEEBLER
February 23, 2026, 4:16pm
4
the last 2 on the year, does not work, only copies (right(%origyear%,2)) in ββ
note: im using tag to tag
NEVER MIND
I forgot the $
my fault
KEEBLER:
I forgot the $
Yes, each character is crucial.
This includes the ones you can't see, such as leading and trailing spaces.
