I noticed that if I have COMPOSER tags on a few files formatted like for example:
Macdermot/G. Ragni/J. Rado
Nina Simone, A. Irving
and I want to reach something like
Macdermot\\\\G. Ragni\\\\J. Rado
Nina Simone\\\\A. Irving
that splits COMPOSER into separate tags so that a robust music player could read that as separate persons and not like a single one.
If I do it one file by one everything is OK, but if use a conversion action Mp3tag gives me the correct final result, that is Macdermot\\G. Ragni\\J. Rado but the COMPOSER tag is still a single one. If I open ALT + T and then click OK to save even with no mods, it finally split values..
Hope that I was able to explain it, otherwise please ask for details (not english mother-tongue)
Is there any solution here?
thanks guys, see you!
Perhaps this is misunderstanding.
The \\ is an indication for and in MP3tag that there should be a multi-value field
The split happens when the \\ is detected and another "save" happens. This is what you see when you check the files in the GUI.
When you apply an action, the \\ is saved in the tag but no further "save" happens - this happens again, when you check the file with the GUI.
If you want to have the same effect that after you got the \\ into the tag field and that splits the tag field, the you would have to create an action of the type "Split field" after the insertion of the \\.
So the action group would consist of (at least) 2 actions: one to get the \\, the other to use the \\ as indicator where to split the field.
... I noticed that if I have COMPOSER tags on a few files formatted like for example:
Macdermot/G. Ragni/J. Rado Nina Simone, A. Irving
that splits COMPOSER into separate tags so that a robust music player could read that as separate persons and not like a single one. ...
This should create a multi-value tagfield for the given testcases ...
Action "Format value" ... or ... Convert "Tag-Tag"Field: COMPOSERFormatstring:$replace(%COMPOSER%,'/','\\\\',', ','\\\\')From:Macdermot/G. Ragni/J. RadoNina Simone,A. IrvingTo:Macdermot\\\\G. Ragni\\\\J. RadoNina Simone\\\\A. Irving
the point is not showing that tag as separate in Mp3tag itself, while see the correct persons names in music players.
As I seem to understand this last suggestion should have no effect on tag as it is saved, so in music players I will still see persons name as Foo Bar\\Bar Foo instead of Foo Bar; Bar Foo as shown when the ag is split
EDIT: or maybe I completely misunderstood that, sorry!
