Begin Action Group Test_2013#MatchTextInTextlist
Action #1
Actiontype 9: Remove fields
Fields to remove (semicolon separated): TMP_GENRE
Action #2
Actiontype 14: Import text file
Field __: TMP_LIST
Filename: 'T:\TEST\GenreList.txt'
Action #3
Actiontype 5: Format value
Field ______: TMP_LIST
Formatstring: $regexp($char(13)$char(10)%TMP_LIST%$char(13)$char(10),'(\r?\n){2,}','\r\n')
Action #4
Field ______: TMP_COMMENT
Formatstring: %COMMENT%
Action #5
Field ______: TMP_ITEM_1
Formatstring: $regexp(%TMP_COMMENT%,'^(?:.+?,\s){0}(.+?)(?:,\s.*|$)','$1')
Action #6
Field ______: TMP_ITEM_2
Formatstring: $regexp(%TMP_COMMENT%,'^(?:.+?,\s){1}(.+?)(?:,\s.*|$)','$1')
Action #7
Field ______: TMP_ITEM_3
Formatstring: $regexp(%TMP_COMMENT%,'^(?:.+?,\s){2}(.+?)(?:,\s.*|$)','$1')
Action #8
Field ______: TMP_ITEM_4
Formatstring: $regexp(%TMP_COMMENT%,'^(?:.+?,\s){3}(.+?)(?:,\s.*|$)','$1')
Action #9
Field ______: TMP_ITEM_5
Formatstring: $regexp(%TMP_COMMENT%,'^(?:.+?,\s){4}(.+?)(?:,\s.*|$)','$1')
Action #10
Field ______: TMP_ITEM_6
Formatstring: $regexp(%TMP_COMMENT%,'^(?:.+?,\s){5}(.+?)(?:,\s.*|$)','$1')
Action #11
Field ______: TMP_ITEM_7
Formatstring: $regexp(%TMP_COMMENT%,'^(?:.+?,\s){6}(.+?)(?:,\s.*|$)','$1')
Action #12
Field ______: TMP_ITEM_8
Formatstring: $regexp(%TMP_COMMENT%,'^(?:.+?,\s){7}(.+?)(?:,\s.*|$)','$1')
Action #13
Field ______: TMP_ITEM_9
Formatstring: $regexp(%TMP_COMMENT%,'^(?:.+?,\s){8}(.+?)(?:,\s.*|$)','$1')
Action #14
Field ______: TMP_GENRE
Formatstring: $ifgreater($len(%TMP_LIST%),$len($regexp(%TMP_LIST%,'\n('%TMP_ITEM_1%')\r',)),$trim(%TMP_GENRE%', '%TMP_ITEM_1%,' ,'),%TMP_GENRE%)
Action #15
Formatstring: $ifgreater($len(%TMP_LIST%),$len($regexp(%TMP_LIST%,'\n('%TMP_ITEM_2%')\r',)),$trim(%TMP_GENRE%', '%TMP_ITEM_2%,' ,'),%TMP_GENRE%)
Action #16
Formatstring: $ifgreater($len(%TMP_LIST%),$len($regexp(%TMP_LIST%,'\n('%TMP_ITEM_3%')\r',)),$trim(%TMP_GENRE%', '%TMP_ITEM_3%,' ,'),%TMP_GENRE%)
Action #17
Formatstring: $ifgreater($len(%TMP_LIST%),$len($regexp(%TMP_LIST%,'\n('%TMP_ITEM_4%')\r',)),$trim(%TMP_GENRE%', '%TMP_ITEM_4%,' ,'),%TMP_GENRE%)
Action #18
Formatstring: $ifgreater($len(%TMP_LIST%),$len($regexp(%TMP_LIST%,'\n('%TMP_ITEM_5%')\r',)),$trim(%TMP_GENRE%', '%TMP_ITEM_5%,' ,'),%TMP_GENRE%)
Action #19
Formatstring: $ifgreater($len(%TMP_LIST%),$len($regexp(%TMP_LIST%,'\n('%TMP_ITEM_6%')\r',)),$trim(%TMP_GENRE%', '%TMP_ITEM_6%,' ,'),%TMP_GENRE%)
Action #20
Formatstring: $ifgreater($len(%TMP_LIST%),$len($regexp(%TMP_LIST%,'\n('%TMP_ITEM_7%')\r',)),$trim(%TMP_GENRE%', '%TMP_ITEM_7%,' ,'),%TMP_GENRE%)
Action #21
Formatstring: $ifgreater($len(%TMP_LIST%),$len($regexp(%TMP_LIST%,'\n('%TMP_ITEM_8%')\r',)),$trim(%TMP_GENRE%', '%TMP_ITEM_8%,' ,'),%TMP_GENRE%)
Action #22
Formatstring: $ifgreater($len(%TMP_LIST%),$len($regexp(%TMP_LIST%,'\n('%TMP_ITEM_9%')\r',)),$trim(%TMP_GENRE%', '%TMP_ITEM_9%,' ,'),%TMP_GENRE%)
Action #23
Fields to remove (semicolon separated): TMP_ITEM_1;TMP_ITEM_2;TMP_ITEM_3;TMP_ITEM_4;TMP_ITEM_5;TMP_ITEM_6;TMP_ITEM_7;TMP
_ITEM_8;TMP_ITEM_9
Action #24
Fields to remove (semicolon separated): TMP_COMMENT;TMP_LIST
End Action Group Test_2013#MatchTextInTextlist (24 Actions)
Test_2013_MatchTextInTextlist.mta (2.63 KB)
DD.20131113.1943.CET
