Since version 2.91 there are no more displaying Matroska chapters. Is there a workaround?
Yes.
Enable "List chapters as separate files" at Options > Tags > Advanced and reload the directory. See also this entry from the changelog:
[2019-01-10] NEW: added advanced configuration option to toggle listing chapters as separate files (disabled by default). (#19589, #42399, #43935, #44112, #44127)
Thanks a lot for the immediate response!
