md5 for cover
Hello,
I have a problem with exportation in .xml : I want to put md5 of the album's cover but I don't find the specific term. Maybe %_cover_md5% ?
Thanks.
As you cannot see the md5 value for tags separately you would have to export the covers first, then set the File>Options>Tags>File extensions so that MP3tag also reads the jpg-files.
Then read the folder so that the jpg-files show up in the files list.
Then create a report that includes the variable %_md5% (for the whole file). This will create the md5-value also for jpgs.
Esp. if you want to see covers in XML you would have to have the files in the file system anyway.
THX
the code for my .XML :
jpg
%_cover_size%
1440
1440
<md5_checksum>%folder.jpg%%_md5%</md5_checksum>
<file_name>folder.jpg</file_name>
