I have a long list of actions on my pc, is there a way to merge these actions with the database on my laptop or import them
Thanks
Thanks
See the documentation - I could not decribe it any shorter:
Doesn't that simply tell me how to backup & restore not merge
Or can I expand the backup to show individual actions then add from the pc backup ![]()
If you want to transfer only individual actions, then
To open the configuration folder, use File>Open configuration folder
Thank you . . . . . . . . .
