Merge multi-value fields and set order
Hello. Is it possible to change the order of multiple tags?
Example:
Artist:DOMOTO & Yulua Oreshko
Artists (with multiple field):DOMOTO\\Yulua Oreshko
Then I change artist tag by action: Yulua Oreshko & DOMOTO
But how to change BY ACTION the order of artists tag (with multiple field):Yulua Oreshko\\DOMOTO
Create an action of the type "Guess value"
Source: $regexp($meta_sep(artist,==),(.*)==(.*),$2\\\\$1)
Target format string: %artist%
Your View -> Extended Tags (Alt +T) are currently looking like this, correct?
And you would like to see it like this?
Yes, correct. I like to see it like this on second screenshot
Source: $regexp(%artist%,(.*) & (.*),$2\\\\$1)
Target format string: %artists%
Thank you, it works, if to use "artists" exept "artist":
$regexp($meta_sep(artists,==),(.*)==(.*),$2\\\\\\\\$1)
Often I change the order in the tag "artist":
$regexp(%artist%,'(.*) & (.*)','$2 & $1')
Flight of the Falcon & Nataliya Gyurd -> Nataliya Gyurd & Flight of the Falcon
Now I will change the order of tag "artists" too
For future readers:
The above solution let you swap exactly two parts in the content of your ARTIST Tag, if exactly one ⎵&⎵ character divide the two parts.
It don't let you set the order if two or more ⎵&⎵ character exists in the ARTIST tag.
Example: ARTIST
Yulua Oreshko & DOMOTO & Third & Fourth
Fourth & Yulua Oreshko & DOMOTO & Third
It also don't let you set the order if three or more multi-value ARTISTS exists:
Example: ARTISTS
Yulua Oreshko\\DOMOTO\\Third\\Fourth
Fourth\\Yulua Oreshko==DOMOTO==Third
