I have a number of quite sophisticated scripts for maintenance with MP3Tag.
Some of them have more than 50 function calls and are quite complex.
Due to a change in my workflow, I am now faced with the task of turning two scripts into one.
How do I get them into an MTA file for further processing?
Unfortunately I don't see any easy and automated way.
The other way around:
Why do you think that merging two scripts toghether will have any benefit for you?
(Besides the obvious few mouse clicks you may save).
The motivation to try this is that about 20 functions in both scripts are redundant, but more than 30 tested functions together should form an important building block for my future workflow.
This tool let you load 2 different files and then compare them and show you the differences.
You can decide if you want to move a difference from the left side to the right side and vice versa.
Maybe this tool can help you to merge the relevant parts into one file.
This is also not an automated way, only a visual help.
