Hi there, I've just downloaded and installed v2.18 (which works great thanks!
). I just notice that some french message were not translated or too long.
. I you need some help I'll be glad to give some help (in french of course).
Best Regards,
Dom-
Hi Dom,
it would be very appreciated, if you can translate/fix the strings in the french language file. The file is called mp3tag.lng and is stored in your Mp3tag installation folder.
Best regards,
~ Florian
Sounds good, also could you send me the english language as ref (I'm too laisy to install it again in english....
Thanks,
Dom-
Dom,
the language file is on the way ...
Best regards,
~ Florian
I'm sorry, but I forgot to update the language file for the current release. I'll do this to the next version
Hi Florian,
I've just downloaded the new version 2.19
but the french translation is still the same one. There was a problem with the file I sent you ?
regards,
-Dom
I simply forgot it, because I was to busy with fixing things.
~ Florian
