Is it possible to show the metadata when it as only one audiofile(i use it a lot for audiobooks), to see what is in the audiofile, instead of doing ALT+T before?
in the adjust tag information, i know its just a detail, but i thought to ask.
I simply do not understand your question
I will rephrase my question please, is when there is only one track it shows nothing in the Metadata Title, instead, if it is only one track maybe show all the metadata? i thought to ask.
If you mean showing the existing metadata from the file (as in the extended tag dialog), then the answer is no. I don't want to mix this behavior in the tag sources dialog.
