mfc42.dll :6907 error? what I'm gonna do now?
when I try to run the program, an error occurs
Mp3tag.exe file, missing mfc42.dll according to 6907
it must be something like that because I might not be translate that correct
and also it hasn't been an hour since I reinstalled windows :frowning:
I don't understand what's wrong with that I had used Mp3tag before
Don't worry :slight_smile:
Everything is okay with your Windows installation - simply extract this file to the Mp3tag program directory and try again.
Best regards,
~ Florian
whoa :w00t:
you're great it's worked I downloaded that dll after I wrote the post message but it didn't had the same effect
thank you :smiley:
