Last and final update. Works perfect!
Link for downloads: Topic
You can Update my exports Florian.
Preview of:
html_milka_album_overview.mte
html_milka_album_list.mte
html_milka_album_mixes.mte
Attachment 222 not found.
You can Update my exports Florian ! ! !
I updated the download links. Florian has to take care of the previews.
1st of all GREAT job, i really love this program and your export lists, both are exactly what i was looking for.
I have some little problems, probably it's my fault, with the generated album/lists. I followed the steps from the guide and i can't see what i'm doing wrong:
Next and Previous album links doesn't work for me. when clicking on it it displays a error message saying that couldn't find file ".../DIRECTORY/NEXT_ALBUM.html". The file it asks for does't exist. Have i got to create it manually? What html code should i put inside it?
In the song list, ALL the song names are links to the 1st one. In the status bar of my internet navigator (firefox) all of them point to the same file. Is there any way to fix this?
This isn't really a problem. The "Pictures" link always opens 2 possible images (cover.jpg and cover2.jpg). Is there any way that it displays all the images in the same directory as the songs are? The only way i found was to edit the export config file so as it takes also cover3.jpg, cover4.jpg, etc. but it makes too long when, for example, getting lists of a entire discography where every album have a different number of cover images.
Please sorry my english (it's not my primary language) ![]()
Thanks!
Thanks
I have made some fixes, and new exports will be available in a few days.
Problems:
".../DIRECTORY/NEXT_ALBUM.html" YOU HAVE TO CREATE IT MANUALLY!
In the song list, ALL the song names are links to the 1st one. FIXED!
Pictures YOU HAVE TO ADD MORE PICTURES MANUALLY, EX:
dynimages'['0']'='['"cover.jpg", "cover.jpg"']'
dynimages'['1']'='['"cover2.jpg", "cover2.jpg"']'
dynimages'['2']'='['"front.jpg", "front.jpg"']'
I asked my friend to write a program that will automatic write links for the next and previous albums, and picture links to. But he dont have any free time, so if someone can write such a program, it will be great. Thanks
