In previous months I have gotten appropriate positioning of my CDs metadata, as should on this page ...
But now I am not getting the metadata properly set for the CDs:
Can you tell me what is not set correctly in EAC or MP3Tag?
ManyThanks!
does this help?
With this meta data is missing from Win10 Explorer, can the CD files still successfully be loaded into Plex?
I am not quite sure what the implementation of Windows Explorer has to do with Plex.
I think that you are the one who has the proper test environment - I don't have Plex. So try it.
And to get the point across: the metadata is (probably) not missing - the explorer simply does not show it. See MP3tag whether the data is still there.
