all my column info is missing i was in it earlier with no problem but now all date is gone. also closing the program is taking about a minute after i click on the red x. i am using 3.01
Thanks
Thanks
I bet that you installed MP3tag with the standard installation mode instead of the portable one or the other way round.
Have a look a this thread where you can find user settings:
You then would have to look for your old user settings and copy them to the new installation location.
Since i don't need the portable why would i install it. i always use standard option. anyhow i just uninstall/reinstall and lost changes. thanks for the help. mp3tag is just like all the rest of the music management programs out there.
Then it is not plausible that you lost your settings.
MP3tag is a tagging program not a music management program.
