Missing functions for conversions
With the windows version, I used functions to convert tag to filenames (or other conversions).
I don't see that functions in the mac version even if I can use it (copy from windows and paste in Mac : $num(%track%,2) - $caps3(%title%) for instance)
Do I miss something or will this be added later ?
Thanks in advance
It's not available yet (although the functions are) and will be added to the menu that appears when you press the + button.
Thanks Florian for your so quick answer :grinning:
I've added the functions (and the information fields) to the menu that appears when you press the + button with Beta 4.
Great, just tried it and it works perfectly :+1:
