Hello,
some of the modals where you can edit info are opening on the wrong displays. I found a thread about it on this forum, but not a proper bug report. (Thread id is 8422, I would've linked it but I can only post 2 links as I'm a new user here)
Steps to reproduce:
- Open MP3Tag on any display
- Use a feature like Tag - Filename or Filename - Tag
- See some modals being opened on wrong display
Example video: https://www.youtube.com/watch?v=ssD1JP1mzRo
Expected result:
The modals should always open on the display where MP3Tag is currently opened.
Here's a Google sheet with the behavior of different modals: https://docs.google.com/spreadsheets/d/12nEaAJPj-z5hz-CG4rplrVeU6diqYsquCLRKzhuI2vk/edit?usp=sharing
And an image of my display setup if that is of any help:
Operating system: Windows 10 Education version 1903 (build 18362.418), 64-bit
MP3Tag version: v2.99a
