I have hundreds of files that have no titles in the tags but the filenames are named correctly, my question is there an easy way to have the file name copied to the title?
would save me alot of copy and paste... Thanks
This is definitely something that can be done with mp3tag. Do you have a couple of actual examples of some of your filenames that you can share so a concrete solution can be provided?
Silly me I should have done a better search term, I found answer and it is working! Thanks for the quick response!!
