Movement Number Assistant (Suggestion)
Hello Florian, hello all,
I am currently working on lots of classical music files and would find it helpful to have a movement number assistant. It would basically work like the Track Number Assistant only with the MOVEMENT and MOVEMENTTOTAL fields.
Would something lik this be possible? Or is there any other suggestion?
Kind regards
Gernot
How do you number the movement at the moment?
You try an action group for the selected files with
  1. Action of the type "Format value" for MOVEMENT
    Format string: %_counter%
  2. Action of the type "Format value" for MOVEMENTTOTAL
    Format string: %_total_files%
Thank you - that works quite nicely.
