Does anyone have a script that will move files from one directory to another, and create a structure by Genre\Artist\Album ?
if you have your mp3 tags filled with genre, artist and album then use an action of the type
"format tag-field"
on the field %_filename%
and enter as format string
%Genre%\%Artist%\%Album%
this will create the named file structure under the current working directory.
If you modify "%Genre%\%Artist%\%Album%" to an absolute path on your drive like
\music\%Genre%\%Artist%\%Album%
it will create the folders in a folder names music.
Thanks that works. I had to add %_filename_ext% to keep the file name othewise I would get a duplicate file error, so my whole action is
%_filename%
%genre%\%artist%\%album%\%_filename_ext%
I had been playing around and tried %_Directory% which was moving more than the files I selected and giving all files the same directory of the file selected and ignoring their own tags.
Thanks again.
