Moving files up and down for auto-numbering
Hi, new member. For some reason several of my flac rips end up in the wrong sequence. This is particularly true of double albums. Is there a way to move files up and down and then re-number them with the wizard? Thanks for the great software.
You can use the ALT key to move the files in the list view with your mouse.
