MP3 Cover Art Size Adjustment
Im new to the program and am struggling a bit with the following issue. Not sure if its me or not?
I download playlists to put on a USB stick to play in my car. My car will only display the cover art if the jpeg files are 1000 x 1000 in size. Any larger and they are not displayed.
When i download playlists they have cover art mostly slightly too large 1500 x 1500 or 1200 x 1200.
I move the playlists to MP3TAG and when i select each individually, right click on the cover art, i can adjust cover, then the size to 1000 x 1000, save it and everything works fine.
But i am struggling to select the whole playlists and change the cover art size of a large amount of tracks in one go.
When i select a large amount of tracks, the cover art is greyed out, it says cover varies, i right click, select adjust cover, then change the size to 1000 x 1000. After this i click on any track which runs a save procedure which gives the impression its worked.
But when i go back to the playlist the sizes have not been changed.
Am i doing something wrong? Or is it not possible to adjust multiple track art sizes in one go?
Thank you for any help
If in doubt, select all the files,
then try an Action (quick) of the type "Adjust cover".
Please note that the dimensions can only be reduced but not increased.
Thank you so much. This works perfectly. Its saving me so much time now
