I have a problem displaying POPM tags from media monkey. I added the column rating mm with value , field, and sort by all set to %rating mm%
When I have my options tags/Mpeg set to "read ID3v2" the column shows correct values for rating mm. If I change my options to "read ID3v2 and APE" both selected, I no longer see any values for rating mm.
A bug report marked "invalid" https://community.mp3tag.de/t/x-problem-with-mp3tag-reading-tags-of-mp3-files/13256 stated that APE tags "override" ID3 tags. But in this case there is no POPM tag (or rating mm of course). Out of curiosity I created an option tags/mapping Tag:APEv2 Source:RATING MM Target:RATING and I was able to copy the RATING MM (not the raw POPM data) to an APE RATING tag. So after that I could see it by adding a column for the new APE RATING tag. Is there some way to get the raw POPM (not converted to mm stars)? But what I would really like is to be able to see the ID3 rating mm even when tag read is set to both ID3 and APE.
scott s.
