Is there a program where i can put random images on mp3 tags instead of one by one ?
Now i can select all of the mp3 but when i change the images they have all the same image / cover i want to give them different zelfmade images
Thanks in advance
Thanks in advance
If you use the action to import covers from file, you can use wildcards like *.jpg or tag field variables in format strings to generate filenames.
This is about as random as it could get.
If, e.g., you have files with a number as filename, you could use the variable %_counter% to get different files.
