MP3 Tag "remixer" not shown
Hello Community,
I am working as a DJ and I use Recordbox version 7.0.9 and there is a MP3 Tag field named "Remixer"
With this field I differentiate the different mix names like extended or radio edit...
Unfortunately I am not able to make this Tag available in MP3Tag
Maybe it is just a wrong mapping of the MP3Tag but to be honest I don't know how to fix this
Thanks for support
Sven
Get a file from which you know that it already has a tag field for remixer.
Open the extended tags dialogue to see the name for the field.
Customize the file list and/or the tag panel according to the documentation
and add an object using the field name from the extended tags dialogue.
Ok opened the extended tags field but it is not listed
In an windows tool I have the tag is %remixedby% but even I add this it is not shown
Here is a list of supported standard tag fields, perhaps MIXARTIST is the compatible field.
Other programs my store such information in their own database and not in the file's metadata. Which would mean that the field is not present in the files and also it could be that the player does not read that field from the metadata.
You would have to try what works with your combination of tools.
Thanks for the help but it is somehow definitely saved in the MP3
Another program showed this
So there must be somehow a tag ID which is not shown or I enter it wrongly.
Maybe the developer of the tool can get in contact with me @Florian so we can find the issue...
Define a column for %_id3v2_unknown_frames%. This will show you if there is an unsupported field.
Do you have APE tags in the file(s) but you do not read and/or write them?
It could be that the update is already in the file(s) in the ID3 tags but not in the APE tags.
If you read APE & ID3 then APE overrules the display of the ID3 tags.
Switch off reading APE tags as a trial.
Topic is solved.
There have been several issues
a) APE Reading was active and
b) remapping of some IDs was active (already active when it was installed)
With the help of Florian I could solve the problem
So this Thread can be closed from my point of view
Just to clarify for completeness: it was a mapping for ID3v2 from MIXARTIST to MIXARTIST which is not active by default when the app is installed, but which caused the field to be no longer visible.
