If an mp3 file is with mpeg extension, instead of mp3. mac version is crashing
How do you load such files in Mp3tag? I'm asking because the *.mpeg extension is not one of the supported file extensions.
drag and drop the files
Still not possible, which version are you using?
latest version from app store v 1.2.2
I dropped 6 files together
Still no success, also when dropping multiple files. Are you on Big Sur or somewhere earlier? Can you send one of the offending files?
I am using Catalina.
I will send the files and also make it crash. Provide the report.
I am testing it again and again. mp3tag is not crashing now!
I am not able to duplicate the crash. You can close this issue now.
If it happens again, I will report back.
Thanks
