Mp3Tag 3.34.1 does not display existing tags
The latest Winx64 version of this program does not display the existing tags on files when I drag and drop them into Mp3Tag. All of fields for the tags are empty.
It works OK over here.
What kind of files are these?
Do you have APE tags in the files?
What are the settings in Options>Tags>Mpeg for the various tag types?
Se also here:
As it turned out, the (FLAC) files I had downloaded did not have any tags or metadata. Never seen that before. Thanks for your reply!
This is unusual for the traditional online sellers. But if these were from an online seller I would send them feedback about the expected but missing metadata.
