Hello,
does anybody knows the parameters for adding songs to the vlc playlist via the tools option?
THX
Hello,
THX
Google: with search "vlc command line parameters" come up with
Read there ...
http://forum.videolan.org/viewtopic.php?f=...t=65006#p221412
... and there ...
/t/966/1
DD.20110113.1340.CET
Edit. Broken link to Videolan removed.
DD.20111121.1256.CET
Paste the code below into ur parameter settings
--playlist-enqueue --one-instance "%_path%"
Basically the code says open VLC playlist | Only one instance to run | and the path of the files.
Copy directly from code above as there is much needed spaces in there.
See attached screen-shots for how I have mine set up.
Thanks for this to-the-point solution. It works fine.
