I was thinking about using MP3tag as a replacement for the built-in database functionality found in earlier versions of MMJB (like in version 7.5 which uses some ID3 fields in a "proprietary" manner).
But before installing it, maybe somebody can help save me a bit of time by answering a couple of basic questions?
I would like to view the tags of all MP3 files in a table format (like an Excel worksheet) and I would like to do this using almost all of the screen area. Is this possible with MP3tag?
I would like to customize the tag display by adding a couple of fields, or changing the existing names. For example, if MP3tag has a field that I never use, could I change its name to say, Preference and then use that field to contain a value from 1 to 5?
If so, can I specify the field's length??
Thanks in advance. I hope I don't have to create what I need in Access or Excel
