Hey guys! How's it going? Hope you're fine. I'm a VideoDj and use the software Scrath Live by Serato to play videos. It provides the option to add cue points on the video to make my life easier saving it on the tag. But since I've changed my computer, if I edit the tag info with MP3tag, it would delete my cue points added previously.
It didn't happen on my old computer... I thought it was probably something in the config, so I've mirrored my old PC settings, also using the same version.
Any idea?
Attaching an image to show the tag. It does not change after I save on MP3tag.
