This worked nicely previously, but now, mp3tag fails to read a folder full of my music, the folder resides on a QNAP NAS , which is using SAMBA to map my folder
I open the folder and it doesnt display any contents, even after a refresh, despite me knowing my music is there
My ideas are as follows: you have recently switched to WIndows 7 and you are now puzzled that no files are displayed in the folder if you invoke a "Select folder" from within mp3tag? This is so because Win7 does not display any files if it is told to select a folder.
If you open the folder in the WIndows Explorer and copy the path from the address box into the path entry box in mp3tag, does mp3tag open the folder? It should.
