i'd like to have mp3tag in portable version
does anyone have it ???????
I second this request.
Edited:
Can't we have all Mp3tag settings stored into an .ini file rather than using the registry (with path specifications defined as relative according to the program location when possible)?
I could then use it directly on my usb-player...
Digging a bit further, I found that generating a configuration archive (File/Save configuration...) and extracting it in the application directory will do the trick! Cool...
The last unsolved thing is the "Directory" dropdown in the Tag panel:
- There's no mean to clear the previous items,
- I couldn't provide a relative path.
Regards,
Dom
You can use [Shift+Del] for that.
Kind regards,
Florian
i see that making this brilliant program mp3tag is unpossible to make in portable version.
Such a pity...
It's possible.
