Hello. I got Windows10 2H20, and try to Install MP3 Tag from mp3tag.de
The Problem is,
It seems to be taking a long time to install the program. Anyone, who can help?
Is this a first installation or an update installation?
This was a reinstallation after windows10 reset (with deleting everything, also there was no more data befor3 installing. Lastet 30 minutes, now its okay
If there is a lot of data in the installation or data folder, then it takes a lot of time to create the uninstall script.
I once had the freedb as part of the MP3tag data folder and that took hours - or would have taken. I aborted, moved the freedb folder and everything was over in a couple of seconds.
