Mp3Tag is not exporting all my cover art
Is this what you mean?
Exactly.
This would export all your cover pictures in 1 single directory.
Yep it worked. Thank You.
Every time I stumble into an issue. There's always a method to fix it. Mp3Tag is very customizable.
Just for the record:
The above Format string does not completely prevent the problem of 'stopping at creating ~100 identical filenames'.
The risk that you have the same filename with the same cover dimensions more then 100 times seems to be pretty low to me.
Its a good temporary solution
Just for the record (again):
The problem is solved with the change in Mp3tag v3.30f:
3.30f (2025-08-01)
  • CHG: removed limit to stop after exporting covers with 100 identical names via action Export Cover to File. (#69294)
