ok, so whenever i right click on an mp3 file, the mp3tag is missing from the rightclick menu but when i rightclick on a folder or say a harddrive, it appears on the rightclick menu... this is something new to me since i was comfortable on editing 1 mp3 file at a time... i need help... what will i do? thanks!
Same here.
You can reinstall Mp3tag. But it will vanish after some time again
If you use Windows 7 you can try
/t/9794/1
