Until recently, selecting some media files and right-clicking them would bring up a context menu including MP3Tag.
Now, for some reason, MP3Tag is no longer appearing on my Win11 PC, but does still show up on my Win10 machine.
It may be a local issue, but has anyone else had similar symptoms?
There are plenty of issues with Win11 and the context menu. There are several solutions that have been shared here.
Meem
January 24, 2025, 2:11pm
3
I don't kow what's problem with Windows 11 with this issue!
I moved all needed Registry keys from other Windows 10 computer, but it still does not appear.
So, I tried "Send To" solution before I relize that is the only solution you have until now.
I hope you able to fix it as soon as possible.
This his not one of the recommended steps.
Have you tried the simplest variant:
Right-click context menu is missing on Windows 11
Assuming you've already restarted explorer.exe via the right-click context menu in Task Manager (or have rebooted Windows), this is happening sometimes on Windows 11 for reasons which I still trying to find out.
What might help in those cases and when the classic context menu is preferred, is to manually register the shell extension from a command prompt with admin rights:
cd <path to Mp3tag installation>
regsvr32 Mp3tagShell.dll
Meem
January 24, 2025, 2:23pm
5
Yes, I have just done regsvr32 trick from other thread.
Thank you.
