Mp3tag not showing tag informaton
It is showing there is a tag in tag column and is showing codec bitrate ect.
but is not showing artist albumn and title information I know exist.
Can you tell me why it is not being displayed
The file probably contains an (almost) empty APEv2 tag which is preferred over the ID3v2 tag. Just try to disable reading of APEv2 at Options > Tags > Mpeg if you don't use it.
Kind regards,
Florian
Thanks to Florian for solving this problem. I would have never gussed it.
